1982 Johnson 35hp hard time starting
drewshep
I have an 82 Johnson 35hp that has a rope start. It is extremely hard to pull. It will start but its so hard to pull the rope. It should not be like that, i have to use two hands and use my weight just to pull it once. PLEASE HELP
You need to post much more information !--------Did you just buy it ?----------Have you checked gearcase oil ?-----Did it suddenly get hard to pull over ?
Don Hansen
Something is wrong. I have to place my left hand against the motor to brace myself but I can start my 35hp one handed and I'm 72 years old.
drewshep
i did just buy it but it has been sitting for a year. we put carb cleaner and it runs when started but super hard to start. No i have not checked the gear case oil.
Michawilden
I have an 30 hp johnson. These bigger two cylinders can be quite hard to start by hand. You will have to put al lot of effort in it. Especially if you are used to smaller outboards. However, something can be faulty. Try to remove the plugs and than cranck it. It should be easy. If so, your engine is fine. If it is still hard to crank it you might have a problem with the recoil starter or worse. But does the engine run good? If the engine is in overal good shape, it should take 2 or three good pulls to start it.
drewshep
Yea it runs fine. It pulls easy with plugs out so i guess its just a hard motor to pull.
Don Hansen
Just looked in my service manual. It talks about timing marks on the rope starter. There's an arrow on the disk under the mounting bracket that rotates when you pull the rope. That arrow is suppose to point between 2 marks on the mounting bracket when the rope is completely wound up. Looks like the bracket has to be off to see the marks. Or maybe you can see them with a small mirror. Not sure what the timing does but maybe the rope was shortened at some point. If you need to change the rope post the question on this site because there's a simple trick you need to know.
drewshep
I don't think the rope needs to be placed. I guess its just the engine size that makes it hard to pull.
NO---On some motors the pulley is eliptical.-----Look at the pulley and you will see the groove for the rope is not round.----The pulley was engineered to give you more leverage on the compression of the cylinder to make it easier to pull.----Confused by this , then take the recoil to a dealer to explain this to you.
