I use a simple continuity tester all the time to determine where wires begin and end -- self-powered light with a probe. The wires of your emergency stop switch on the handle probably run to the mounting bolt for a coil and a single amphenol connector running to the power pack. These are negative wires.
If you locate the wire end points at the engine, you can test the switch by simply connecting the tester between the ends. The tester should light up if the clip is removed (completes the connection) on motors with the lanyard and clip. Similarly, it should light up if the stop button is pushed on motors equipped with a stop button. If the light stays on with the clip in place/stop button released, assume the switch is defective (which would prevent the engine from starting by shorting out the ignition).
believe you have a 7 1/2, btw, based on the model number posted. I think the '82 would have a stop button on the lower cowling, not a lanyard and clip -- but not sure.
