1982 Evinrude 8 hp E8rcnr
thatone123
Banned
This outboard will not spark, seems to be in tiller handle. How do you get the wires out of the handgrip? Seems you must take the idle.and stop switch knob off the end of the handle, but I see no way to do it? I use a simple battery test light to test the electric system by simply seeing what wires and terminals do not light. Anyone else use this method? Thanks!
???----Why not simply disconnect the ground wire for that switch to test for spark.
Vic.S
What Racerone says. Confirm that there is a short to ground, or that the stop switch is defective before tearing the tiller apart,
However there are two little catches, locking tabs, or whatever you want to call them, that locate in the plain part of the twist grip which when depressed will allow the grip c/w switch and wiring to be removed ( disconnect the wiring first obviously)
oldboat1
I use a simple continuity tester all the time to determine where wires begin and end -- self-powered light with a probe. The wires of your emergency stop switch on the handle probably run to the mounting bolt for a coil and a single amphenol connector running to the power pack. These are negative wires.
If you locate the wire end points at the engine, you can test the switch by simply connecting the tester between the ends. The tester should light up if the clip is removed (completes the connection) on motors with the lanyard and clip. Similarly, it should light up if the stop button is pushed on motors equipped with a stop button. If the light stays on with the clip in place/stop button released, assume the switch is defective (which would prevent the engine from starting by shorting out the ignition).
believe you have a 7 1/2, btw, based on the model number posted. I think the '82 would have a stop button on the lower cowling, not a lanyard and clip -- but not sure.
Vic.S
ITYWF that the model quoted has the stop switch mounted on the end of the tiller, but it is just a simple stop button, not a safety lanyard type. At least that is what is shown in the official parts list.
thatone123
Banned
Thanks guys, having some trouble with this new format and passwords. Anyway, The guy I got this motor from already had started in on the handle and after testing the other electrics it seemed the handle stop button was the problem. I did unbolt the ground wire and there was still no connectivity in that wire from the stop button. BTW that knob unscrews I found out so that the holder for the button comes out. Then you pry the button past the 4 clips and it comes out. That knob also lets you fine tune the idle. Don't know how it does that as looking at it I see no connection to the idle system? Anyway, the button was full of salt, that is why it was not working. Got it cleaned up and working but still lost the cause as when forcing the handle back on the tiller I broke some of the plastic inside that must turn the bolt that turns the throttle cable, so now need a complete new handle or that part anyway. Thanks again for the input!
Vic.S
Do you realise that the engine is stopped by pressing the button to close contacts ? The lack of connectivity you describe will not prevent the engine running./ kill the sparks.
The idle speed adjustment works by limiting the travel of the throttle mechanism, There is as you have noticed no actual connection. It takes quite a bit of turning to make a relatively small change in idle speed.
All the parts, except the main parts of the handle. should still be available separately. See the BRP parts list for part numbers
oldboat1
Just to add to Vic S's comments, don't confuse the throttle stop on the tiller handle with the idle adjustment on the carburetor. The carb adjustment needle at the top of the carb body adjusts the fuel/air mix, and is important to getting the motor to idle and throttle up smoothly with no hesitation or stalling -- in combination with a squeaky clean high speed orifice.
The throttle stop on the handle is useful for setting a trolling speed, or to keep the motor from idling too slowly and stalling out -- provided you don't want it to do that. You can effectively set it to stall the motor, and shut it down that way. (That's provided you can get the blasted thing to work. I've had a mixed record with that.)
thatone123
Banned
The button shorts out but connecting the 2 copper contacts in the handle...right? Yes, the non-carb idle button/knob design experiments on the various small OMC's can be frustrating. The large side button on the 9.9/15 comes to mind. Other than that the best modern portable ever made!
