1982 Evinrude 15 hp replace water tube???
rifflerunner
We picked up a 82 Evinrude 15 horse that was only dribbling out the pee hole so we relaced the impellar and seals. Didn't work. We have water coming out of the area in the lower end where you can see the linkage pass through. When we shoot compressed air up the water tube and plug the pee hole we can hear a major leak somewhere inbetween. Should we relace the water tube and how is that done.
Thanks, Rifflerunner
clanton
Re: 1982 Evinrude 15 hp replace water tube???
Remove the powerhead and replace the rubber grommet at the top of the tube. New grommet should fit below the lip of the tube. you can flex the tube to recover the lost 1/4 length. Factory fix
