1982 Evinrude 115 - Cooling system disconnected
charliepenner
The pee hole for the water in the head unit is disconnected and I can not figure out where it is supposed to attach to. I have checked videos, looked for manuals even ran the motor to see if water came shooting out of somewhere. Is there anyone that would have a photo or diagram showing exactly where the hook up coming from the engine would be on its way to the pee holeIMG00123-20120902-1409.jpg
Joe Reeves
Re: 1982 Evinrude 115 - Cooling system disconnected
There is a large plate located between the cylinder heads (exhaust baffle plate). The water telltale outlet (plastic fitting) would be located at the bottom starboard (right) side of it.
charliepenner
I looked, there is a place where it looks like it should be but there is a screw in there, is this it??
Daviet
I wounder if someone eliminated the tell-tale for some reason?
charliepenner
I disconnected the lines and confirmed that the water is running through the cylinder heads for cooling, i already checked that, would that mean that it will still be cooling enough for running?
Daviet
The tell-tale is only an indicator of water pump operation, it does not need the tell-tale for engine cooling. You can run without it, but it is nice to have a visual indicator for the water pump operation.
charliepenner
Good to know, thanks for the help
Joe Reeves
View attachment 166330 View attachment 166329
That is not a standard exhaust baffle plate of a 1982 115hp model and the coloration of that plate immediately came across to me as a 1973 135hp tuned exhaust baffle plate. What is the model number of that engine?
If the model number indicates a 115hp model, then someone has tried to Mickey Mouse upgrade the hp to a 140hp model. The 115hp baffle plate is flat, not bulged out.
