1982 16' sylvan sportster pics
bryanwess2000
ezmobee and rickairmedic asked me to post some pics of my
sylvan since they're basically the same as a supersport.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
So far all i've done is replace the transom with some 3/4'' 7 ply coated x3 with
gluvit. I plan on using it to do the floors this winter. I predrilled all the holes in the transom and coated with gluvit before installing the transom. I was in a hurry to get the boat out on the water so the splaswell and drain tubes
just got healthy doses of 5200 sealant, not the prettiest but it works. I have a 1977 mercury 85hp mounted that puhes it 36-37mph. I expect I can get around 39-40mph after I get it set up properly and remove the added weight of the foam, as i'm sure its water logged considering the boats leaks about 2
gallons over 5-6hrs on the water. It's got a few loose rivits and one broken
at the very back of the hull. The paint looks ok from 10-20ft away but it's
got bubbles and large runs in it and it's chipping off in several places. The original floor is rotten so the PO put 3/4 ply over it and covered it with house
carpet. So it's got alot of work needed.
Rickairmedic
Re: 1982 16' sylvan sportster pics
Bryan thats a good lookin rig you have there and if you are sneaky and grab a set of Northbeaches nice Starcraft Logos and put them on it nobody would know the differance and EZ and I wont tell :D.
Rick
stevenw00
Nice boat. I've got an '84 18' Sportsman. Mine is also going to need some wood work before long, but I think I'll get another couple of seasons before I really dive into it.
