fishingdan
- Feb 12, 2005
- 1,045
ser 6010145
I want to replace my poppet valve and after looking at it, I have a couple of questions.
1) My Seloc manual has no section on maintenance for this part. Am I missing it somewhere?
2) While the serial number on my engine indicates that it is a 1982 engine, the poppet valve diagram (engine block diagram) on Mercury parts express.com shows the part differently than what I see. On the diagram, the poppent valve cover is basically a circle. On my engine, the poppet valve cover has an appendage that extends back (in the direction of the cylinder head) a couple of inches. I took the cover off and the appendage covers a cast recessed area in the block that is about 3/4" in diameter and about a 1/2" deep. There is no opening in this hole. What is the purpose of this recessed area?
3) Given that my actual part doesn't match the diagram online, how do I find the parts for this? I am guessing that the internal poppet valve parts are the same, but the cover gaskets are different. Maybe this engine has a rebuilt powerhead.
Thanks
Thanks
