For this weeks update:
I got the motor on a stand and was working on it.
Lifted the cover and found a large mouse nest.
Tested compression: all three tested at 140psi.
Got looking at the wiring and noticed the mice chewed a few of the wires.
Found the plate having the serial and model number of the motor.
Not knowing when the last time this motor ran I figured there would ne a few parts I would have to replace as a preventative measure, likt water pump, thermostat, LU oil, spark plugs, coil packs, carb rebuilt kit, silinoid.
Bad news is I was trying to shift the LU into forward and reverse to see if the gears were good. Could only get it into forward. It would come out of gear but not fully into neutral. Could not get it to move far enough to go into reverse.
My question may sound stupid but will it hurt to wash down the exterior of the motor? Anything besides the carbs that I shold not get wet?
