ross_larter
Thread starter- Joined
- Apr 6, 2003
- 109
Hi All,<br /><br />I have a 1981 Mercury 70hp 2 stroke with a power problem:<br />This is what i have tested.<br />- Out of gear It rev's fine.<br />- In gear with the prop half out of the water and the water intakes under water , it revs ok and throws water up in the air.<br />- It has been compression checked OK.<br />- The carbs have been cleaned, and the fuel lines checked.<br />- the 3 plugs seem to be giving a spark.<br />- the pee hole is peeing OK.<br />- the throtel is opening fully.<br /><br />The problem is that when it is trimed under the water the revs drop and it only pushes the boat at about 5mph (It will do this for as long as you want won't stall).<br /><br />any ideas ?<br /><br />Cheers<br />Ross
