1981 Fibreform/Runabout with 50 HP Johnson Cleanup
jjhann
Just found my first boat last week and spent alot of time cleaning and scrubbing to get her gleaming again.
1981 50 Johnson on the back. Not sure the make/model of the boat, she's been handpainted a couple times. Looks like a Fibreform ?
Also came with a canopy....that is not 100% waterproof....water just soaks through it.
She was left in the alders/trees and quite a mess.
Next project is the cracked up vinyl/dash, new stereo, speakers....and see about the tach and speedo gauge.
Throttle controls are all hooked up and working...but there's 2 sets of wiring coming from it that are not hooked up to anything. Both have a grey and black wire inside of them ?
Before:
After so far..............
gm280
jjhann, I see you've been busy cleaning and such. Nice before and after pictures as well. I would say before venturing too far with stereo and such, check the transom, floor and stringers for any problems and/or rot. Those things have to be addressed first for safety reasons. If you don't know how to check for a good transom, drill a few 1/4" holes as low on the transom as you can (about an inch or so deep, don't drill through) and see if wet dark soggy shaving comes out. If so, you have a transom to repair. If dry light wood shavings come out, then the transom is good and you can plug those sample holes with some epoxy or polyester resin and check the floor for soft spots. If the transom and floor are good, then install the stereo and whatever you wish and happy boating... JMHO!
NAT1VE
Like posted above check out her stern before you go any further :lol:. Also Starbrite PTEF spray will help restore the water resistance to your canopy. If it is pretty dirty buy some 303 fabric/vinyl cleaner.
studioq
I also have a 50 Johnson on my boat - so I'll be interested to see how that goes. I've already done a little maintenance to mine. Still waiting to do the "major" stuff such as the impeller and gear case oil change. The sooner you can get the motor running the better.
And not to be a downer - but you've got a LOT of inspection to do before she goes in the water - and if she wasn't garage kept - you might not like what you find in, under and around the floor as well as across the transom. Being open to rain for that long never really does watercraft any favors..
jjhann
floors good, previous owner had a wooden canopy to cover her and I have it now. Wasnt covered this year since he became ill. Had her out on the water and ran like a champ.
fishin98
Nice OLE boat....follow those wires back to the beginning...hopefully there is a fuse block.....some people use what wire they have when hooking up a accessory.
Woodonglass
Honorary Supreme Mariner
This is true ^^^ and it's always advisable to use Marine grade wire when wiring a boat!!!:encouragement:
