ezmobee
Thread starter- Joined
- Mar 26, 2007
- 23,767
I have a suspicion that my motor is not charging the battery. I haven't had any issues with a dead or weak battery but I have a brand new overkill-sized marine starting battery that I do throw on the charger at home from time to time. So it's possible it's just never been drained enough to be a problem. My motor starts easily also so it's not like I've done a lot of cranking.
Anyway, the reason I suspect I have this problem is that I just recently installed some gauges (had none before) and attempted to connect the tach to the gray lead in the control box and also installed a voltmeter. Well my tach doesn't work at all and the voltmeter never moves off of 12V. So I'm thinking my charging system is not working. I probably would have just assumed a wiring issue with the tach pulse feed if it were not for the constant 12V reading on the voltmeter.
How do I verify that I do indeed have a problem, and if I do, I believe it would either be the stator or rectifier that's bad. This motor starts and runs PERFECTLY. Would that indicate a probability that my stator is good? or does the stator have nothing to do with anything other than charging?
Thanks everyone.
Thanks everyone.
