1981 evinrude 25hp vertical throttle shaft
Dave mugs
Please help! !! I installed a new vertical throttle shaft because the original broke, took the boat out to test ran fine for 40 seconds in gear and the throttle shaft snapped again. What could be causing this???? They are $80 new and i don't want to break another.
Need a lot more information.----Those shafts simply do not break !--------How long have you owned it?------Was any other work done on this motor ?------Any parts out of position under the flywheel ???
Dave mugs
Thank you so much for your reply! ! I have owned the motor for two years and have done normal maintenance carburetor, thermostat, and impeller. about 2 weeks ago I had to super glue a piece of plastic on the neutral safety switch that broke off. see picture attached of the broken shaft and the neutral switch. I don't know of any work that was done before I owned the motor.
Dave mugs
As I was digging in a little further it sounds like something is rattling around Under the flywheel. I am going to pull later today and see what is in there.
Dave mugs
Ok. So 2 screws came loose and they were binding up the flywheel and in turn snapping the throttle shaft. Do these screws on the magneto come loose often? How difficult is it to change the upper seal? It is leaking all over the mag. Can i change the seal with the magneto plate on or do i need to take it off?
I have seen parts come loose more than once on these.---See post # 2 on that.---Seal is fairly easy to change with plate in place.
Chinewalker
I've seen the little phillips head screws that hold the plate to the retainer come loose and cause issues. A drop of LocTite might help prevent that. Any damage to the stator or trigger?
The upper main seal is the easy one to replace if needed. Lacking a seal puller that goes over the crank and threads into the lip, you can sometimes punch the tip of a drywall screw through the seal casing, thread it in a turn or two and use it to pull the seal out. A screw on both sides will help you pull it up evenly. Then you can press a new seal in place using length of PVC pipe of the correct diameter to evenly press the new seal downwards.
Dave mugs
Sorry i will re post pictures. I don't see damage to the stair and not quite sure what the trigger is. flywheel is a little nicked up on the underside I will try and post that as well but not too bad. there is one Phillips head screw that I cannot find where it goes I will post that as well. I will definitely be using Loctite and the PVC pipe is great idea thank you.
Dave mugs
in the fourth picture the screw to the right the Flathead was one that was dislodge. of the Phillips screw is the one I cannot figure out where it goes.
Chinewalker
The Phillips head screw goes on one of the holes along the outer edge. Not all of the holes get screws. It'll go in one that goes through both the stator plate and the support ring under it.
Dave mugs
Ok..which hole from this picture do you recon it goes in? It is possible i can't figure out where it goes because it is striped and won't fit in any hole.
oldboat1
No Title
Maybe this helps -- pic of a motor I was working on at some point. The orientation of the plate would probably be the same -- might be you are not using the right holes. I struggled with that too. View is from the front of the motor.
btw, can't see the dropbox pics (probably because I'm too stubborn to sign up). As an option, get a pic of choice to your desktop, then click on the camera icon on the left when ready to attach. Follow the prompts.
(edit. Phillips screws. Fourth one hidden in pic -- left rear of plate.)
Dave mugs
U da man. Thanks that helps. I think it goes in the hole next to the flat head for the wire retainer. Sorry about the pics I have been posting from my phone and that is the only way it will let me do it. But that screw is stripped would u happen to know the size and tread size maybe i can find at a box store? Marineengine.com does not give me a size.
oldboat1
sorry -- can't come up with the info, but yeah, think you might be able to carry it in to a hardware store to get one that would work. Or, could buy a couple at that site or elsewhere (shipping costs, I know). And if you have any parts from prior projects, you might have something to fit.
Dave mugs
Awesome thanks sir... I wish I could post some pics but I can not even on my computer. Sorry
oldboat1
You're welcome D., but check back in -- guys here may have the specific specs.
