1981 evinrude 25hp vertical throttle shaft
Chinewalker
Keep in mind, those screws are specialty screws. They have an unthreaded shank on them that allows the screw to thread through the plate, drop a hair, then thread into the retainer. This allows the clamping effect to take hold. Also prevents lost screws when servicing, as you don't need to remove the screw, just loosen it from the retainer.
Dave mugs
Gotcha!! I believe i found where it goes because this is the only other spot where there is a hole that looks to be machined on the through side. I still cant get anything in there because it is stripped out. Do you guys think it will be ok to go without this screw?
