TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
You guys were a great help several months ago when I was originally trying to get this engine running after about 5 years sitting idle. Since I got it running back then (April I think) it hasn't been started and when I tried starting it today, it won't start. <br /><br />I have fuel coming out of the carbs when using the choke on the key or the manual choke so I know the carbs are working and I verified that I have compression and spark on all 4 cylinders. When trying to start the engine, I get a bit of smoke (bluish white like it's burning oil) from the two holes in the housing below the power head and I get oil coming from where the prop meets the bottom of the housing. If this was a 4-stroke, I would say that having air, fuel, compression, and spark would be good enough for it to run but I'm not as 2-stroke savvy so if there is anything I should look at, please let me know as I was hoping to get this boat wet tomorrow.<br /><br />Thanks in advance for your help.
