Bosunsmate, i took the flywheel off and looked at the stator i lightly sanded all the contact pads on the stator and the flywheel to ensure good contact. i looked at all the wires but couldn't see all the wires. there is one wire that has some kind of rubber around it. where were yours grounding out
Not sure what these contact pads are you mention. Nothing in there is a contact pad that needs good contact with anything else. The bits of metal i think you mean on the stator work by being in close vicinity to the spinning magnets in the flywheel, they should never touch the flywheel at all which is why alignment of the stator is really important. You can probably see grooves where it needs to sit. I normally put a bit of lipstick or something arather on them and then spin the flywheel and make sure none comes off on the flywheel.
Im not sure if sanding them may of damaged then. Could be tme to buy a $5 multimeter and do an ohmns test on it.
My wires were grounding between that rubber thing and the outside edge of the top of the motor.
When you put the flywheel back on you have to torque it down to 100foot pounds no ifs or buts and also make sure the flywheel key is lined up.
You can also use the $5 multimeter to check that none of the wires have a short to ground, including the timing base ( which is the small circle thing under the flywheel and inside the stator ring. It works by magnets on the inside of the flywheel whereas the stator is on the outside magnets
