1981 50hp evinrude spark problem
Phrogger
I have a 1981 50hp evinrude. With the motor running at an idle the bottom plug is getting absolutely no spark. I have swapped the coils and nothing changes. I suspect the power pak is going out but I have been told that when one does go out it just happens. When I get the boat on the water it will spark sometimes and then die off. You can hear and feel the motor rev up when it catches spark. Any suggestions?
Phrogger
Bosunsmate, i took the flywheel off and looked at the stator i lightly sanded all the contact pads on the stator and the flywheel to ensure good contact. i looked at all the wires but couldn't see all the wires. there is one wire that has some kind of rubber around it. where were yours grounding out
Phrogger
Racerone, it runs a little better with it off but not like it should
Bosunsmate
Not sure what these contact pads are you mention. Nothing in there is a contact pad that needs good contact with anything else. The bits of metal i think you mean on the stator work by being in close vicinity to the spinning magnets in the flywheel, they should never touch the flywheel at all which is why alignment of the stator is really important. You can probably see grooves where it needs to sit. I normally put a bit of lipstick or something arather on them and then spin the flywheel and make sure none comes off on the flywheel.
Im not sure if sanding them may of damaged then. Could be tme to buy a $5 multimeter and do an ohmns test on it.
My wires were grounding between that rubber thing and the outside edge of the top of the motor.
When you put the flywheel back on you have to torque it down to 100foot pounds no ifs or buts and also make sure the flywheel key is lined up.
You can also use the $5 multimeter to check that none of the wires have a short to ground, including the timing base ( which is the small circle thing under the flywheel and inside the stator ring. It works by magnets on the inside of the flywheel whereas the stator is on the outside magnets
Phrogger
Yes I thought those were contact pads that generated electricity. So I sanded the rust off of them. I have a multimeter and never even thought of ohming it out to see if it had a loss of power. Or to ground to see if it was grounded good. Ok so the two magnets that are on the bottom side of the flywheel are for timing? I will try that and see if the wires are grounding out
The goodies under the flywheel fire both cylinders via the powerpack.---So if it can fire one cylinder the fault is likely the power pack.---Not expensive and easy to replace.
Phrogger
That's what I'm thinking just want to rule everything else out so that it isn't wasted money
If the one sensor coil and the one charge coil are good enough to fire one of the cylinders then----
Bosunsmate
None of them sould be grounded, if you get any conductivity seen on a multimeter between the two brown wires and ground you have a short
????-----These timer bases use only one charge coil and only one sensor coil in firing both cylinders !!!-----If one cylinder is firing that would indicate nothing wrong under the flywheel.
Bosunsmate
Yes that might be right, i could be getting my 60hp mixed up with my mates 90
Anyway cant hurt checking those values, i always do them on any electrical problem i get, like a compression test equivalent
Phrogger
No Title
I'm not understand this. This is from the cdi manual. But do I do this with it running? If I do then that means I have to unplug the power pak and if I do it will not run. I just don't understand how all of this works. When it is running and I have it full throttle the bottom cylinder will catch spark and the boat will take off. Then it dies off. Sorry if I didn't mention this. Hope it helps
Phrogger
And I can't find where the timer base is or what it looks like to know how to check it or what
Bosunsmate
You just unplug the plug, engine off and stick your multimeter in the holes that match with the coloured wires they talk of.
To do the voltage ones you need a peak voltage ac reader which is an expensive bit of gear. Resistance values normally tell you if somethings up.
You should clean all the ground connections too, their bolts etc
Bosunsmate
Timer base on that is just the sensor coil which is included in the stator ring.
You test that with engine off too (resistance test), unless you have an expensive dva meter
Bosunsmate
by the way you need to look up the values for your motor, that page you posted is for a motor with two banks of cylinders
