1980's serial number / harness / general questions
acadian2022
hi. its lifted and well secured but will need more feedback as to how / what tools is required so far all has failed. I've been treating the assembly with WD40 specialist penetrant and no luck thus far will keep doing researche on my end and invite any suggestions. when I look at this assembly that is 2 part right and left and bottom brace seems to me engine has to be off the boat ?
Dukedog
with #28 and 29 removed it should drop out.... don't remember any "special" tools but its been a minute since i did anything like that!.. like 20+ years.
Dukedog
jus wanna self correct.. they did build a "crank rated 200" in '82 that did have tha vertical front half.. only year that happened... so it is technically a 200... sorry my bad.............
acadian2022
no worries at all. my issue is 28 is it to be pulled out? screwed out? I used a slide hammer a few shots to see if it would move some nothing
acadian2022
10 minutes later :) I may have figured it out! Ive been heating up the pivot pin every so often while working on other stuff and adding WD penetrating formula when looking at the part diagram you sent I'm going to take a heavy duty bolt that fits in the center of the pivot pin use the impact short shoots and try to make it spin will keep all updated if this works thank you all once again for the help....
acadian2022
still won't budge...
acadian2022
Quick update nothing Ive done worked. I was able to tap a new hole in the ram and got the power trim system to work for now this will do and get back to this another time thank you all for all the suggestions / help
acadian2022
good day. anyone know what are the specs for the power head bolts serial number for the block is 6033659 and the head number is 95081. I was trying to replace the buzzer alarm sender and snap 2 bolt within OMG... any way if I cant extract them I wont have a choice to remove the power head and replace all bolts. I know they are 3/8 however dont know the length and want to ensure if I decide to attempt to extract them would need bolt specifications if anyone could help please
