1980 West Bend re-coil problem
meyerboy
If you own a west bend (chrysler) then you will know what I am talking about. The engineering on the starter re-coil has GOT to be the reason Chrysler stopped making outboards.
Mine is a 4hp sea king, and the teeth on the swing-clutch won't grab the inside of the flywheel. I took the teeth off, and sharpened them on a grind wheel, better, but not good enough.
I tried tape on the inside of the flywheel, worked great, but tape won't stick.
I am stumped...... there are other poorly built components on this motor, but this is the worst I have ever seen.
any ideas??
M
mrcrabs
Guest
Re: 1980 West Bend re-coil problem
buy an old dependable Eska and then watch ebay for Chrysler parts
F_R
Honorary Supreme Mariner
Actually, that starter design was used on lawn mowers too...Clinton if I remember correctly. Yep they were kind of funky. I used to sharpen them too.
