captaincanuck
- Aug 26, 2011
- 4
hello guys,I have a 1980 merc 70 horse 3 cylinder.
my problem i have is i had it tuned up and got it to start no problems with muffs on.
I put it into gear and idles nice both forward and reverse.
the problem is i went to put it in the water and give it a small run around the lake ,it fired up no problem .
after i had it at idle for a minute i put it in reverse and started to back out from the dock just at idle.
when i put it in forward gear it did the same thing no problem.
then i went to give it some gas and it sped up a little then it would not take anymore it just kept dying?????
forward or backward it did the same thing.
so i pushed the button on the shifter to allow you to use the shifter for gas with out it being in gear and it reved up fine no problems at all.
but once again trying to get it to take some gas after it idles it just keeps quiting.
please any help you could give.
regards ,gord.
regards ,gord.
