1980 / 85 HP Evinrude water pump. Help
Rapio
I'm removing water pump prior to installing new water pump kit. Have done this 3 or 4 times previous. This time impeller won't release from shaft. Instructions say, turn shaft counterclockwise to unlock impeller key. Turning shaft and jamming impeller doesn't release. Infact can't really turn shaft while holding impeller.
Only difference this time is: Prior to operating season, I took gear case to very experienced local dealer for pressure and vacuum test.Invoice indicates no leaks, but water pump was raised to replace lower gasket....Thanks
Honorary Supreme Mariner
Just bump the impeller one way , then the other way with screw driver and hammer. It will come loose on the key.
Rapio
Thanks racerone. A few of the above and a bit more hold and turn. The impeller is looseTime in 10:41 time out 11:41. Can't beat that. Thanks again.
