1980 25hp Johnston outboard
Bill705
How do you reset the rich/lean setting knob to the factory setting\?
I think the engine is running too rich and would like to lean it out a bit but not too much!!!
larryg
Re: 1980 25hp Johnston outboard
turn the knob in to lean.should be 1 1/4 turn out from light seat.then just find the sweet spot.when its found pull knob off gently and set it at 12 oclock.
Daviet
You only have an adjustment on the low speed circut, the high speed is fixed.
