Re: 1980 17' Magnum 171 Rebuild
GT1M, Can the foam be sealed with some kind of paint or coating? It seems like aluminum foil would tear easy and you would still have the same problem.
Ooops! Sorry, I missed this...thanks for bumping it...
The idea behind the aluminum foil is simply to act as a barrier between the resin and the foam, so that the chemicals in the resin don't "eat" the foam...
There really should be no reason for the foil to tear, since you should only be laying wet out layers of cloth on the form...
Also note that you need to seal any overlaps of the foil with some clear packing tape to prevent the fumes and the resin that may seep under the foil and deteriorate the foam...
The heat generated by the process of the resin curing also generates a significant amount of heat which could also melt or distort the foam...
The aluminum foil
may or may not help with this also.
The denser the the foam the less this will be a problem...
In the past, I worked at a scenery production company where we made all kinds of "props" for TV and Videos...
We did use latex paint to paint foams, including plain old EPS [ extruded polystyrene, aka styrofoam] to seal them against the detrimental effects of the resins...also note that most of the resins we used are the same ones most boats are built out of, polyester resin, not epoxies...
Sometimes we even used expanding urethane foams to make molds and then cover them with fiberglass, it was an expensive and time consuming way to do it, but the biggest advantage was being able to make complex shapes and not having to worry about the resin eating into it...
In most cases, if the foam was thoroughly and properly sealed, after the first layer of resin soaked cloth was applied, there would be very little or no distortion/melting of the underlying foam...
Afterwards, any subsequent layers would have no effect on the original foam form...
In some cases we even went back and removed the foam form because, for whatever reason, the final shape needed to be hollow...for those times we would spray PVA on or mold parting wax, to the completely foil wrapped form before applying the resin...
There are special foams available that can withstand direct applications of resin, you just need to search for them...
There are also special core products, like "Nidacore" and their equivalents that can be used the way you want...the caveat is that 3M, the owner of "Nidacore" has decided to cease all production of these products, so you will have to look for NOS wherever it may be, or look for a different manufacturer of these products...
Hope this helps and great looking progress on the demo, so far...Keep up the great work!
