1979 or so Glastron Trihull
Heeneytick
Help needed please? Have a 79 "ish" Glastron Trihull with a 100hp Johnson. Last time we had it out 6 years or so ago we had issues with it popping out of gear and not staying in gear when trying to load it on the trailer making it next to impossible to land. Am sure it's in the linkage but never worked on cables before. Any advice is greatly appreciated and thanks in advance!! Boat is immaculate and would like to get it back out for kokanee run this fall!
s.hadley81
Welcome aboard! Sorry I'm not much help on the outboards but you might have better success of a good answer by posting in the Johnson outboard section. Sometimes a moderator will come along and move your post for you. Best of luck to ya!
jbcurt00
Moved to the Johnson OB forum
If the boat is from the late 70s, the HIN in the upper right corner of the exterior transom will provide the year.
To get any real help, youvll need to privide the model# of the Johnson OB.
What does the title/reg list as the year, w out paperwork (depending on your state) I wouldnt spend much time or any money working on a boat or its OB, until the paperwork is in order.
emdsapmgr
There are three possible reasons for poor shifting. 1. The shift cable is not adjusted correctly under the cowling on the starboard side. There is a thumbwheel which screws in/out and will adjust the cable slightly. This is the easy adjustment. 2. When you remove the lower unit (perhaps for a new impeller) the shift rod gets exposed. If during the changeout of the impeller, the shift rod and get twisted-that can wind up being a big problem. During factory assembly, the shift rod height is set to a very specific height. (like with a 1/32" tolerance) If this rod is not put back in the exact position, the engine won't shift correctly. Have to pull the lower unit down again to reset the rod height. 3. If the gears get worn from years of shifting and use, it is possible the gear faces and the clutch dog faces will get worn. When they get too worn, the gears do not want to stay engaged, even if the shift is set perfectly. This is a more major job, which could result in a new clutch dog, forward and pinion gear. You may want to have a skilled tech look at this for you.
Heeneytick
Thank you emdsapmgr, I will look into that next weekend and see what I discover! I greatly appreciate your insight! Am in hopes it's just the thumb wheel to be sure! At least I have a place to start, thank you and everyone else thus far. IT's greatly appreciated
