1979 Johnson 100 Low Compression
mackinawmarauder
Evening,
I've got a 79 Johnson 100 Javelin (100TLR79S) that gave me starting issues out on the lake last year. Typical symptoms - starts fine on muffs but once in the water it takes a certain amount of finesse to get it to start. Originally I thought it was a fuel issue and got all new lines and rebuilt the carbs. Yesterday I decided to do a compression check, knowing in the back of my head that I wouldn't like the outcome.
Compression check was done with a fully charged batter, motor was cold and I got 49-50 in all four cylinders.
So now I'm having a dilemma. My father thinks I should just tune it and run with it till it dies since once started and warmed up in the water it has no issues staying running or moving around on the lake, then the day it does die upgrade to a newer engine. I on the other hand think a top-end rebuild would get me some more life out of this engine since everything else works well on it.
What would you do? Anyone in this situation had good luck with rebuilding the top-end?
I did pull the heads and did not observe any gouging or scoring of the cylinder walls.
If I did land up re-building the top end would a simple hone and new rings/pistons do the trick, if tolerances are fine?
oldboat1
Would first get a second opinion (another tester). See if you can borrow or rent one. Test with plugs removed -- crank until needle stops moving, then note reading and move on to the next one.
jbuote
Hey there, :welcome:
Yeah.. That is low... I haven't done a rebuild, so I'll let the others here comment on that..
You'll find all the help and info you need here.. Great bunch of folks on this forum..
I'd only suggest that if possible can you confirm the low readings with another gauge?
Low and even like that I'd personally like a verification that those reading are correct and it really is that low..
(EDIT: Ok... oldboat1 beat me to it.. haha!)
Just a thought..
jimmbo
As mentioned, redo the compression test with a different gauge. Myself I would give the engine a carbon cleaner soak for a few days to see if there were any sticky rings(it is 39 years old). If you have access to a camera, to put down the sparkplug hole, to look at the cylinder walls.
mackinawmarauder
I did pull the starboard head yesterday to inspect the walls, they looked good (for a 39 year old engine). There was a lot of built up carbon on the head of the piston which is to be expected.
Is there a certain carbon cleaner you all have used in the past and had good results with? Seafoam?
oldboat1
Like your Dad suggests, running it might get the job done. Techron is a good additive. Seafoam often seems to invite more problems than it solves, although maybe that is an application issue. Run with fresh gas and a good TCW3 two cycle oil
interalian
You can also inspect rings by removing the bypass covers on the sides of the block. Compression that low, if verified with another gauge, could indicate broken rings. If they're broken, it's only a matter of time before one gets caught in a port which will cause a lot of damage.
flyingscott
Highly doubtful that motor would start much less run with those compression #s. Different gauge before anything.
Honorary Supreme Mariner
Pull the starter apart for inspection.---Costs nothing.
