1979 Glastron ssv-177 outdrive question
handyandy
My question is about the 1979 Glastron ssv -140 outdrive with a mercruiser 140 h.p. Can anyone tell me if a Mercruiser Type I pre 1985 888 outdrive will fit? Thanks
SpinnerBait_Nut
Re: 1979 Glastron ssv-177 outdrive question
Mercury/Volvo/OMC I/O and Inboard questions and repair forum.
Welcome to iboats.
Ayuh,.........
The 888 Outdrive will Bolt On,........
But,.......
It's the Wrong Gear Ratio,.... 1.5/1.....
You need a 2/1.......
And,.......
No,..... You can Not make up the difference with a Prop Change..........
