1979 evinrude...help please
kdsmith2292
i have a 1979 evinrude 115hp motor and the shifter will not go into the reverse position..anyone help?
HighTrim
Re: 1979 evinrude...help please
Just out of nowhere, or is this motor new to you, or had you been doing something to create this problem?
kdsmith2292
i had just bought the boat around a week ago..but no wen i bought it, it would not go past neutral
boobie
First off disconnect the shift and throttle cables from the mtr. Then try it. This will tell you if the prob is in the control box or the mtr.
HighTrim
First off disconnect the shift and throttle cables from the mtr. Then try it. This will tell you if the prob is in the control box or the mtr.[/QUO
Of course boobie means to try to shift it from the motor after the cable has been disconnected. I know that it seems that this would be given, but I actually had someone call me once with this problem, told him to disconnect shift cabe and then try it, so he did, from the control box, lol.
He called back and said it still wouldnt go into reverse, geesh, some ppl ;)
boobie
What I meant was by disconnecting the cables you are seperating the control box from the mtr. You could have something wrong on the mtr or else something broke in the control box. This narrows it down as to what area the prob is in.
Bob_VT
Motor running??? Sometimes you need to turn the prop by hand just slightly. It is fairly common if the motor is not running.
