1979 Evinrude 100 XP power tilt and trim
Rusty123
My power tilt and trim was working sporadically. It has stopped working completely and I had to change the solenoid more than once when it did work. Would it be safe to assume the motor is the culprit? Do I check the motor by grounding the black wire and then energizing the blue or green wire to change the direction of the motor?
D
DJ
Guest
Re: 1979 Evinrude 100 XP power tilt and trim
Moving to Evinrude/Johnson Repair Questions.
Ayuh,... Assume Nothing...
Yes, black is ground, blue is up, 'n green is down...
