1979 Bayliner Mutiny
boboso99
I'm working on my 1979 Bayliner Mutiny. The engine cover box is a fiber glass shell with vinyl outside cover. The inside insulation has been removed. I want to install an appropriate type insulation. What would you suggest?
HopeSheFloats
Re: 1979 Bayliner Mutiny
Out-boarder here so not much help...do a search here using something like 'doghouse insulation'...been quite a few threads on the subject...sure to give you idea's along with some pro's & con's....good luck and welcome to the site!
Bob_VT
Welcome to iboats!!! :D
Some people have installed plastic type closed cell foam, some have used dynomat, others have used 1 inch foil faced hard insulation board (from a box store).
Just make sure whatever you install will stay tight and secure with adequate adhesive so it does not fall into the I/O engine.
Make sure it has proper clearance too. Do you know what was in there before?
