1978 suzuki spirit 50hp wiring
jeffmetz
i need to know witch wires go where on the key switch. i know the white goes to the bat, brown to the sel. and the red to the push to choke but i don't know where the yellow , green, and the black goes on the switch. i have three more post on the switch they are mag. circ. , ignition , an one that just has an (m) on it.can any body tell me where these wires go? thank you 1978 spirit suzuki 50hp
turn2
Re: 1978 suzuki spirit 50hp wiring
The green kills the mag when key is off, black supplies ground to kill mag, yellow must be ign. green=mag, black=circ,yellow=ign
jeffmetz
Thanks a lot, i was thinking the yellow was the ign. and the green went to the mag. circ. on the switch , and the black to the post that just had the ( m ) on it. i would have had them back words. thanks so much
stylesabu
Master Chief Petty Officer
I believe yellow is for the tach, it is on the 80's suzuki's outboards
jeffmetz
I have a blue wire that is in the harness, but it is not hooked up to the motor . I was thinking that was for the tach.
turn2
If you cant kill the engine swap the green black. not sure about the blue.
jeffmetz
OK, i'm going to go out this after noon and try it, thanks. i'll let you know ho i make out.
jeffmetz
Thanks guy's, It's up and running. Thanks , thanks , thanks
