1978 omc sterndrive service
formula thunderbird
I need to know what lube the OMC sterndrive takes in all three parts of an OMC 800 but can not find any info on the net to service this model of the outdrive assymbley.
any have one and know what oil to use
drained it and looks like common outdrive oil but dont want to mess it up with the wrong oil
Help :)
floattest
Re: 1978 omc sterndrive service
I have that same drive. I used to really like the Sierra "premium" gear oil. Sierra changed the oils they sell and they now call it "premium blend". I don't know what the difference is but I liked the old oil better. Don't have a good reason.
I think Sierra is still a good choice though. Real expensive. You can also get any old premium marine rated gear oil and it will work fine. Save some money if you like.
My advice to you is to replace all the gaskets on all the screws every time you change the oil. Use the nice nylon (medium hard plastic) ones. Use a new one everytime. And replace the rubber gasket on the top screw in the upper and the intermediate. It's like a rubber o ring. Tighten the crap out of all the screws when you have all the oil replaced. The screw has a bead on the underside of the shoulder and that seals into the nylon gasket. If you try to use the gasket a second time the bead can crosss the first seal and you'll get water in your drive. You probably will anyway, but you may as well eliminate as many possible intrusions as you can.
Also fill each drive from the bottom screw with a pump. I pump the upper and intermediate full until oil comes out the top screw. I pump the exact amount into the lower from the bottom. I think it's 38 ounces. Check a manual though. Someone may correct me, but I don't think it's wrong to pump oil from the bottom until it comes out the top and then put the top screw in an then remove the pump and replace the lower screw. Do the same for all three units.
Enjoy your old OMC while you can :)
Howard Sterndrive
80W90 in intermediate, upper and lower
tilt clutch housing calls for 30, but 80W90 is fine in there too to keep it simple
oldsub86
So, what say the rest of you folks? Is it really necessary to change out the gaskets on the fill screws every time?
Randy
formula thunderbird
First thank you for all the input
Replacing the o rings and plastic parts at each screw is a great idea I think I will just go buy a handfull of each piece. Also I see you said I would get water in there anyhow do these always leak water into them and how often should I change this? I am formerly a mercruiser owner and never had this problem with water getting into my outdrive as I serviced my lower unit each season. I purchased this Formlula Thunderbird for a thousand bucks and all it needed was freezeplugs replaced It didnt get winterized correctly and pushed them out under the motor mounts as usual worst ones lol.
I replaced them and serviced all fluids and she fired right up you could probably eat off this engine was very well maintained until the passing of the previous owner and then it didnt get put to bed for the season correctly.
many thanks for the advice as there is nothing online telling how much or what kind
Formula Thunderbird
