1978 Mercury 70hp Worth Messing With?
Mc Tool
Yeah, it just seems easier to temporarily move one wire than to move the coils.
I'd put things back of course.
But if when I do that, and #2 then has spark, I know it's not a bad coil.
yep . One of the things that makes a good mechanic ( or any repair man ) is the ability to diagnose the problem and one advantage a multicylinder motor has over a single banger is the immediate proximity and availability of substitute parts for diagnostic purposes ....by all means swap things over to see what it can tell you . :D
Berdink
I'm learning. 😊
Berdink
Lower unit oil must have been typical gear oil and not marine gear oil, because about a half a teaspoon of clear water came out when I removed the plug.
Oil was black. The plug has a magnetic tip, but I didn't find any metal shavings on it or in the oil.
I haven't started working on it yet. I just wanted to make sure the lower unit was good.
I'll start a different thread if I run into anything I need help with.
But from all my searching; the compression being good, the lower unit gears likely good, I feel better about giving it a chance to live again.
Berdink
Not a robust lower unit for a 70 HP.----...clip...
I'm reading the motor is actually only a little over 60hp at the prop.
But yeah, I just took it off.
It's a little light one. :)
It's on a 1978 15 foot Britton BeachCraft Trihull.
I think it being as light as it is - the whole motor being around 190, I think it'll be an advantage for me. Getting older.
I hope to leak test it Friday.
It looks clean and free from saltwater use.
A couple bang-ups though.
Oh, I should mention, the mounting nuts for the lower unit came off easy, and the lower unit dropped right off. The impeller is semi soft still.
redneck joe
looks fine to me.
i understand the older. decided to sell the 26 foot cabin cruiser on a trailer for an 18 foot aluminum with a 50 hp - about 1800ish lbs all in for that very reason and as fast as I'm going down hill it was the correct call.
Those are some pretty good bangs on the side of the gearcase. You might put a straight edge on 'em and see if there are dents in the casing.
Berdink
It is apart, makes no sense to use the old Impeller, unless it is only a yr old, otherwise, replace it
Yeah, I was only mentioning the impeller's softness for verification that someone had been in there not too long ago.
Mc Tool
Thanks, I bought a physical service/shop manual.
yeah there is something about holding the book in your hand .... its the oily finger prints all over the pages of the section pertaining to the issues your having with your motor :LOL:
Texasmark
On the ignition problem, I'd loosen every connection from/to the packs and once slightly loose, work the wire back and forth which will shine up the contacting surfaces.......then re-secure the locking device....screw-nut. If the (ground) wires under the screw have corroded terminals....which isn't out of the question (especially since there is no corrosion shield like on the pack terminals), what I said will put you back in business, costing you nothing but a little time.
