1978 johnson 55 seahorse not leveling
cub1698
Hey yall, I have a fiberglass boat with a seahorse 55hp. I went for a spin with 3 friends in the boat and it didn't level out. Is the weight to much for engine? Also the props a little marked up but not enough to hinder operation I don't think? Any advice is appreciated
Bosunsmate
ive a seahorse 60hp with a 14foot fibreglass and it levels out with 3 on board, easy as.
You might need everyone moved forward til you level out
or you might want to do a compression test on the motor to check its got the power it should
OBJ
Not knowing if this boat is new to you, let me offer a couple things to look at in addition to Bosunsmate suggestions. One is engine set up on the transom. Look at the anti cav plate (that's the plate right over the prop). It should be set even with or no more than one inch above the keel of the boat. Maybe an inch below or less ain't bad. Too much lower unit in the water creates a lot of drag which equals to poor performance of the boat. Take a look at the angle of the motor and try different angles. You can do this by moving the tilt rod in the transom bracket to a different hole. Do you know what the rpm is at WOT (wide open throttle)? The engine is rated for 5500rpm at WOT. You should get this or be in a range between 5000 and 5500 depending on boat loading. Below 5k and you could start lugging the engine which don't help them out a whole bunch. Check the WOT range with the weight in the boat evenly distributed as Bosunsmate suggested. If a prop change is needed, you can figure roughly 200rpm per change in prop pitch......hope one of the other guys verifies that....having a senior moment right now. Anyways, check things out and let us know what ya find.
jbcurt00
What type of fiberglass boat?
Wide and flat like a jon boat, a bass boat or a semi/deep-V?
How's it run when it's just you?
3 large fellas sitting at the helm and a rear seat at the transom in a heavy 15ft nearly 40yr old fiberglass boat may be more stern weight then the 55hp can overcome.
Depending on the boat's details, and the proper operation of the motor w/ the correct prop to get ideal WOT RPMs, it may not even be a motor problem
cub1698
Deep v, and unable to tell rpms due to no speedometers
