Not knowing if this boat is new to you, let me offer a couple things to look at in addition to Bosunsmate suggestions. One is engine set up on the transom. Look at the anti cav plate (that's the plate right over the prop). It should be set even with or no more than one inch above the keel of the boat. Maybe an inch below or less ain't bad. Too much lower unit in the water creates a lot of drag which equals to poor performance of the boat. Take a look at the angle of the motor and try different angles. You can do this by moving the tilt rod in the transom bracket to a different hole. Do you know what the rpm is at WOT (wide open throttle)? The engine is rated for 5500rpm at WOT. You should get this or be in a range between 5000 and 5500 depending on boat loading. Below 5k and you could start lugging the engine which don't help them out a whole bunch. Check the WOT range with the weight in the boat evenly distributed as Bosunsmate suggested. If a prop change is needed, you can figure roughly 200rpm per change in prop pitch......hope one of the other guys verifies that....having a senior moment right now. Anyways, check things out and let us know what ya find.
