gaffemaster
Thread starter- Joined
- Jul 6, 2015
- 9
Long story short I apparently had water in my lower unit on a 1978 Johnson 25hp short shaft (25R78C) and it froze and cracked pretty good. I bought a skeg from a 1976 and was told by several people that it will work just fine but one guy I spoke with says 1978 was a unique year and I should not use the '76 skeg on the '78 even though it fits. Took it to my boat guy and he took a few measurements and said he would have no problem putting the different skeg on but this other gentleman I spoke with said it would basically be a short term repair. Part numbers on the inside are the same but there looks to be a slight difference in machining in a couple spots. Should I bolt up the '76 skeg and run it with my fingers crossed or should I search for a true 1978 skeg? Or should I look at getting it welded or JB weld it up? I'd like to make the proper repair and not have to worry about it. Any help is greatly appreciated. Thank you.
