1978 johnson 115 tilt trim problems
bubbaj469
New guy here needs some help! OK 1st boat to repair! Ran fine but was sitting a year! Got it home and gas smelt new so fired it and runs fine! Trim rods raise very slow "without motor weight on them"! Tilt not moving at all! Ran it up and down manually, Added fluid. Repeated this 3 times. Left it sit over night and all day with motor weight on all rods. Bled air today then tried raising motor and it was stuck. Worked it a little then it let me lift the motor manually but slow. Raised all rods and refilled with fluid. Left sitting with weight on motor then bled it again! Will leave it over night and day while at work!
Talk to me guys seen a lot of problems solved here! I have tried everything on these post and other google searches! I know chevy trucks and most other autos but this boat has me twisted! Also downloading a manual tonight!
Thanks in advance,
BUBBA
Joe Reeves
Re: 1978 johnson 115 tilt trim problems
The unit is self bleeding, there is no need to bleed it.
Slow running electrical motor? Check/clean all connections terminals etc associated with the PTT unit. Very easy to develop a voltage drop via loose or tight but dirty connections.
Engine at full tilt up position and locked there..... fill reservoir to overflowing, then replace reservoir screw plug.
Check electric motor by running good clean jumpers directly from the battery to the PTT electric motor.
emdsapmgr
Follow Joe's advice on bypassing to the trim motor direct. You could have a bad trim up solenoid in the trim box under the rear spashwell. Check all the connections there to be sure they are all tight.
