1978 evinrude 140 outboard
can some help out sucking air where butterfly passes through carb body can this be repaired if so how 1978 evinrude 140 outboard thanks frank
Usually it is the brass shaft that wears and it can be replaced I think.
boobie
The brass shaft is part is part of the throttle body and you'd have to get the whole body.
emdsapmgr
Are you looking at replacing both the upper and lower engine mounts? Neither job is a piece of cake.
