1978 Elpto 150 hp not firing
bigdan1
I have a 1978 vintage 150 hp elpto mercury outboard , it always ran A-1 ......but now it wont start , no spark ! where should I start looking ? coil, switchbox ? I have a multimeter ......thannks !
Dan ,
Chris1956
Honorary Supreme Mariner
Dan, Is that a V6 or inline 6? If a V6, it will have ADI ignition. You should disconnect the two black/yellow wires at the switchboxes and see if spark returns. If so, your ignition key is likely malfunctioning.
Since Merc did not make an inline 6 150HP motor in 1978, it is either the wrong year or wrong model. You might find out model year by serial number. It likely has a battery powered distributor CDI ignition system.
