wolfman266
- Apr 23, 2007
- 1
Motor has not been run in 2 years. I checked compression around 75 in both cylinders. Which I know is on the low side. I have excellent spark. I tried new plugs. I squirted some fuel directlly into the carb and cyl. I tried starting fluid. The motor will no even make a pop. Other than the keyway in the flywheel is there any other thing that will affect the timing. Does the sensor under the fllywheel have anything to do with the timing. What does it do? I realize I will have to pull the carbs for cleaning. But don't want to stick alot of time in to it until I know that it may run and be worth fixing.
