1978 1150 mercury outboard vertical throttle lever
eplankell
While working on my engine, I needed to loosen the nut on the bolt that passes through the center of the vertical throttle lever and connects it to the engine. Can anyone tell me the proper amount of torque I need to use when re-tightening the nut on this bolt?
Thanks,
Eric
Chris1956
Honorary Supreme Mariner
Re: 1978 1150 mercury outboard vertical throttle lever
Eric, Snug it down until the lever has no play, but does not bind either. It should have a 9/16" nylon locknut, which allows this adjustment.
eplankell
OK - Thanks again, Chris.
- Eric
