1978 105hp Missing at Full Throttle
caegert
I'm sure this has been answered hundreds of times, so I apologize in advance.
My family has a 1979 Chrysler boat with a 1978 105hp outboard engine which runs great as long as it's not at full throttle. As soon as you get the boat at full speed, the engine begins to cutout/miss. It seems to do it more often when turning or when hitting waves. We have replaced the fuel lines, spark plugs, used Sea Foam in the gas, and carburetor cleaner. We have also tried using a different removable fuel tank with new connections. Nothing has improved. We're assuming it's the fuel pump.
I was just wondering what you guys think the problem is and if there's anything else to try.
Thank you.
Frank Acampora
Re: 1978 105hp Missing at Full Throttle
I do have the same problem with a 105 that I am currently testing. Running with the hood off has shown that the pump is delivering foam to the filter, thus starving the engine at full throttle. I checked all connections for air leaks and replaced the pump and diaphragm. I will test this weekend to see if that solved the problem. I strongly suspect the pump and inlet fitting, though, because I previously had a 90 on the back that had no problems with the same fuel lines and tanks.
