1977 Searay Re-Power
matthew0801
I am going to repower my boat it is a 22 ft searay with cuddy if that helps, I want more hp, it has a 190 omc and a electric shift stringer outdrive, wanted to go with a 454 eng, but I was told it would be to heavy, and to go with a 350 chevy, i also will have to do some transome work any advise would be appreciated.
D
DJ
Guest
Re: 1977 Searay Re-Power
Moving to Boat Restoration and Building.
You'll get a better response there.
Solittle
If you go with the 350 what are you going to use for an outdrive? There are not many fans of the OMC set-up here.
erikgreen
If money isn't a problem, go with the 454, more torque is always better. Otherwise the 350 would be good.
Of course, that's size-wise. Are you going to replace the outdrive and transom kit too? With what, exactly?
Erik
oops!
hi matt.......
one suggestion might be to find another boat with the motor /drive setup you want...and exchange it...!!!!...then sell the other one with the old stuff!!!
just a suggestion
cheers
oops
