Flyfishingken
Thread starter- Joined
- Sep 20, 2017
- 7
Hey all, I have a 14ft Livingston with a 25 hp seahorse. I noticed the steering has become very sticky. I have a center console hooked up with a decent steering device. Anyway, when I would go to turn on the wheel I would have to force it, the steering would struggle for a sec and then break free and turn.
So I disconnected the console steering line and just experimented with it. The line is smooth and no issues at all with stick. Then I moved to the motor and it is definitely the culprit. Very hard to steer from the tiller and it "sticks" where ever you leave it at in the turn. So I shot the zerk with the grease gun and turned it a bit but it didn't seem to do much. I saw the grease ooze out the bottom but not the top of the column. From reading on forums here I should maybe heat it up with a blowtorch just a bit and then spray wd40 onto the top joint and the bottom joint? After this maybe turn it a few hundred times?
Any other suggestions? The motor probably sat for about a year before I bought it.
Thanks,
Ken
Thanks,
Ken
