1977 Seahorse Very Hard Steering
Flyfishingken
Hey all, I have a 14ft Livingston with a 25 hp seahorse. I noticed the steering has become very sticky. I have a center console hooked up with a decent steering device. Anyway, when I would go to turn on the wheel I would have to force it, the steering would struggle for a sec and then break free and turn.
So I disconnected the console steering line and just experimented with it. The line is smooth and no issues at all with stick. Then I moved to the motor and it is definitely the culprit. Very hard to steer from the tiller and it "sticks" where ever you leave it at in the turn. So I shot the zerk with the grease gun and turned it a bit but it didn't seem to do much. I saw the grease ooze out the bottom but not the top of the column. From reading on forums here I should maybe heat it up with a blowtorch just a bit and then spray wd40 onto the top joint and the bottom joint? After this maybe turn it a few hundred times?
Any other suggestions? The motor probably sat for about a year before I bought it.
Thanks,
Ken
oldboat1
Don't know what year or model you have, but look for a friction adjustment screw under the powerhead in the swivel bracket. For remote setups there should be no friction -- may not be your problem, but worth checking.
jbuote
Sounds like maybe that might work... Not sure.. lol.. (not an expert..)
​Just wondering if maybe having an admin move this to the "Steering and Controls" section might yield more results and/or help since it's not brand specific?
Up to you..
​Quite sure somebody here in the Johnson Evinrude section can certainly help you out, just thinking exposure for your question..
(EDIT: as oldboat1 replied while I was typing... lol!!)
​For whatever that might be worth...
​Sorry I don't know more..
oldboat1
Up to you..
A Seahorse is a Johnson motor!
jbuote
Yes, I know a seahorse is a Johnson, therefore it's a more than valid question in this section.
​I was just simply wondering if the steering and controls section might also help since it doesn't sound like a "Johnson" specific issue, but rather a stuck steering issue.
​That's all, I meant no disrespect.
oldboat1
I don't feel disrespected. lol. for whatever it might be worth.
roscoe
Better results spraying it with a solvent based penetrating oil than with wd40.
Try pb blaster or aeroKroil or Liquid Wrench
You might even try a little BrakeKleen to get it loosed up.
Vic.S
Thanks,
Ken
As suggested make sure the friction adjustment is freed off.
There may be grease fittings for both the the upper swivel and lower swivel bearings... you only mention one!
If injecting fresh grease does not enable you to work it free it may be necessary to dismantle the steering swivel assembly, clean out all the old hardened grease and reassemble with fresh grease.
Spraying externally with a water displacing fluid such as WD40, or even a decent freeing oi,l is unlikely to be effective
Flyfishingken
Hey guys, thanks for answering. I did back the tension bolt all the way out first. I am at work so I can't really get the year and model number just yet. I have a few pictures I can post though. I only have 1 grease fitting towards the bottom of the spindle. Down towards the lower unit almost. I can't find one anywhere towards the top where I think it is sticking.
So just spraying the top joint and the bottom joint and then turning it back and forth probably won't break it up?
And yes it was used in Salt
Thanks
Note: Evidently I'm not authorized to post attachments so I will get the model number shortly.
Some will argue.-----But here is what happens.-----Salt water on aluminum speeds up the oxidation of aluminum.-----Aluminum oxide ( white powder ) forms between the bearing bushing and the pivot housing----Oxygen JOINS with the aluminum one molecule at a time to form the oxide.----There is now more material there and it can really jams thing up over time.-----Take it apart and scrape out that oxidation / white powder.----No more problems for a while.
Flyfishingken
Ok I got the model it is a 25R77S. I looked all over for a second grease point towards the top by the spindle and can't find one? Any ideas? Thanks guys.
Flyfishingken
So could two guys that are relatively mechanically inclined get it off and back on in a day? Or is this like a month long project? I just read that you don't want to get in there and clean it if you can help it.
What if I drilled a hole towards the top to insert blaster and then just regreased the hole. Seems like I need more access.
Thanks
Chinewalker
Being a salty, it may come apart with difficulty. But, as racerone said, best to take it apart. Not terribly difficult, generally. May be made more difficult by corrosion. Remove the clamshell at the bottom of the swivel, then the two nuts on either side of the motor, below the powerhead. There is one more nut to remove at the front mount, which should be accessible from the front of the swivel, under the carry handle. Then lift the motor, tilting the lower unit rearward, and it should lift free of the upper mounts. You will then have access to the swivel bits.
To reassemble, some finagling may be needed to get the two upper side mounts in place in the steering bracket, but it is doable. Nev-R-Seize on the bolts should prevent future issues if it ever needs to come apart again.
Flyfishingken
Super helpful. Thanks. I think we will give it a shot. I assume I'm going to need something like a long handle wire brush. What would you recommend spraying the shaft with to get it cleaned up? Maybe a PB blaster?
Thanks again.
Ken
oldboat1
Try some cola or vinegar (or both) on the shaft, and a wad of aluminum foil.
F_R
Being a veteran of 24 years of salt water repairs, I can tell you that it is a very common problem and has to come apart. So do as chinewalker said. I might add, remove the vertical throttle shaft from the side of the powerhead, simply to make it easier to reassemble. It really does help if you have a hoist to lift it out, but two guys built like the Impossible Hulk can do it.
Once you get it lifted up/out, you will see a small pin through the upper liner. Drive that pin out from the outside (be sure to catch it). Now you can remove the liner, and you will see the problem. Corrosion. Dig/scrape it out. Then grease it liberally with some good marine anti-corrosion lube and reassemble.
Flyfishingken
Thanks for all the info. I'm probably about a week out from cleaning it but I will be sure to post up some pictures of the inside. I bet it's pretty gnarly.
Can I keep the motor mount on the boat for this? I would hate to pull it off it I can avoid it. It's bolted through the transom pretty solid.
Thanks
F_R
Yes, in fact it is necessary to have it clamped down to something solid & heavy. Like a boat.
