1977 Mercury 1750 V6 outboard flooding issue.
Savage_383
Did a little research and just wanted to double check before ordering parts.
I have a 1977 Mercury 1750 (175hp v6) that hasn't been on the water for 15+ years. The boat has been restored and now I'm trying to get the kinks worked out of the motor.
I took it to the lake for the first time last week. It started and idled fine just like it did on muffs. Getting up on plain was a bit of a stuggle for it at first but finally took off and ran fine for a few minutes. once I backed off on the throttle, it loaded up and died. fuel dumping out of the carbs. I was able to get it started enough to get it back to shore but it would never get back up on plain and eventually wouldn't start and I had to winch it onto the trailer.
Here is what I have done to the motor already.
-Rebuild carbs / fuel pump / fuel tank / fuel lines.
-Replaced Stator and trigger
-tested all coils and wiring from switch boxes
-checked the manual to be sure I was using the proper jets
-checked for spark on all cylinders.
I have not replaced the switch boxes not do I know if they have ever been replaced. could these be the culprit? The reading that I did lead me to believe that these are causing a weak spark.
any suggestions?
Thanks in advance.
gbrowne9
go through your carbs again . floats too high or something jammed between the needle and seat,hense the fuel pouring out the front.
Faztbullet
Replace the floats as they get heavy and cause flooding, the original are likely a orange color and should be discarded if such..
Savage_383
Thanks for the reply and I apologize for my late response. New floats finally showed up in the mail but they are the wrong ones. which leads me to a new topic that I will post in a new thread.
Thanks for the help.
