I have a 1977, 140 Johnson Outboard. The motor is only firing on 2 cylinders, both on one side. I checked both sensor coils with a miltimeter. They both measure within the acceptable ranges in the manual. When I switch the wires from the sensor coil to the power pack, the spark plugs spark on the other side so I assume my power pack is OK. I removed the key switch lead and turned the motor over, the two plugs continue to spark. The manual lead me to believe that this indicated it was either the switch lead or the switch. The lead is fine and I removed the switch and emergency stop button and it still only sparks on two cylinders. What do you think the problem is?
