1977 Johnson 115 Hp
said
Not sure where to expect the water to come out from when the motor is running.
Any input is appreciated, thanks.
emdsapmgr
Re: 1977 Johnson 115 Hp
The overboard indicator (telltale) came out in 1978, the same year OMC went to the different powerhead base and dual thermostats. Your 77 will have a slight indicator of water flow. Start the engine when cold. Hold the palm of your hand back by the two rear exhaust relief ports at the top of the midsection. After a minute or so, the thermostat (vernatherm) will open. When it opens, water droplets will form on the palm of your hand. That's normal and indicates water flow thru the powerhead.
boobie
When you get it in the lake and run it you'll see more water out of them.
mark rohrer
I have a 1973 Johnson 115 outboard,will not idle when in water but will idle all day with ears on,how do I adjust low idle speed to keep running in the water
GA_Boater
You get help by starting a new thread of your own. This one is old, inactive and belongs to said. Look at the Help Tips on top of the page. Thanks.
