Greg Mrozinski
Ensign
- Aug 17, 2009
- 941
Re: 1977 Cruise Boats Restore
Next up is the mounting holes for the motor. In order to obtain the most accurate hole positioning, I decided to hang the motor on the transom and mark the hole placements. I first covered the area with a heavy grade builder?s paper. This helped protect the paint while I positioned the motor in place. I then hung the motor on the transom, aligned it to its proper position and then clamped it into place. I then marked the center location of the four bolt holes using a sharp punch. This allowed for easy centering of the drill bit afterwards.
Once the holes where marked, I drilled them out making sure the drill bit stayed perpendicular to the transom. After that, I carefully taped off around each hole and mixed up a small batch of poly resin with ?? chopped strand. I then coated the insides of each hole with the resin mix to seal the wood and help slow down any future water intrusion.
