stanleythetroll
- Mar 21, 2012
- 22
I have 1977 9.9 hp that won't start. has not been run for some time. it was not firing on top cylinder. found crack in ignition coil. replaced. now i get a pop out of the exhaust. checked flywheel key. looked good. both plugs are firing out of the cylinder. a little fuel will come out the exhaust. it seems like a timing problem,but don't no where to look next. will not evan try to run if i feed fuel sraight to carb. i have not done anything to the carb yet. trying all other options first. thanks!!!
