1977 9.9hp converting to a 15hp...
dfrants
what all is needed to convert a 1977 9.9 Johnson to a 15hp? Didn't they make a kit at one time? is it something a shade tree mechanic can do?
jimmbo
This topic comes up on a regular basis. There is no kit to convert. One just buy the parts they need. What is required, differs depending on the year. Some are just a carb change, others require also require an exhaust tuner change, or a different intake/reed assembly. Can another 1000 rpm really result in a 50% increase in HP?
oldboat1
...but always prior shadetree mechanics. Can look into the throat to check the size (LeeRoy's site has a good side by side of the 9.9 and 15).
dfrants
Found the bigger carb and prop for $20. As a 9.9 she went 19-20mph, now as a 15 she does 22-23mph. and idles just as well.
