nphilbro
Thread starter- Joined
- Dec 19, 2011
- 304
I've got a thread already going on the rebuild of my 1977 85hp motor so now is a good a time as any to ask this.
My parts motor is a 1975 Johnson 115hp. All the ignition components are identical and I used those to fix the ignition problems on my 85.
These two engines were basically built on the same form factor. In fact, my service manual is for both the '77 85hp and 115hp and the two rarely differ.
Could I use the carbs from the 115 on the 85 to increase hp? My parts motor has a cracked block but all the other parts are there and are in reasonable enough shape to use.
Even the gasket sets are identical except for the head gasket. I just checked the exhaust bypass covers and they interchange.
It looks like the exhaust diameter at the thermal housing is slightly larger on the 115 but the bolts line right up - so I could add that to the 85.
I've searched all over the internet but I can't find this question answered.
Any help?
Thanks
NP
Any help?
Thanks
NP
